Hey everyone, I’ve been experimenting with my RGB lights in Home Assistant and stumbled upon an interesting issue. Every time I turn them off and back on, they reset to white. At first, it was a bit frustrating, but I decided to dig into it and figure out a solution.
After some research, I discovered that this behavior is pretty common with RGB lights, especially when they’re integrated through ESPHome. The lights don’t retain their state when turned off because the system doesn’t store the color or effect settings. I wanted a way to save the state when the lights are turned off and have them reapply that state when turned back on.
I started by looking into automations and templates in Home Assistant. I found that using a combination of sensors and scripts could help. Here’s what I did:
- Created a sensor: I set up a sensor to track the current color and brightness of the lights. This sensor updates whenever the lights change.
- Added a script: I wrote a script that saves the current state of the lights to a file when they’re turned off. This script runs automatically when the lights are turned off.
- Modified the turn-on automation: I updated the automation that turns the lights back on to read the saved state from the file and apply it.
This setup has worked wonders! Now, when I turn the lights off and back on, they remember their previous state. It’s been a fun project, and I’m happy to share my solution with the community.
If anyone has other tips or tricks for managing RGB light states, I’d love to hear them! Let’s keep the ideas flowing. ![]()
