Hey everyone, I wanted to share my experience with resolving a persistent issue I had with my Wyze camera. The problem was a loud buzzing noise that would come through whenever I monitored the camera on my iPad or iPhone. While the other three cameras in my setup worked perfectly, this one was driving me crazy!After doing some research and reaching out to Wyze support, here’s what I discovered and how I fixed it:1. Firmware Update Check: The first step was ensuring the camera was running the latest firmware. Wyze frequently releases updates to address bugs and compatibility issues. I found that my camera was indeed a few updates behind.2. Factory Reset: If the firmware was up to date, the next step was performing a factory reset. This can sometimes resolve software-related quirks. I held down the power button for about 10 seconds until the LED started flashing, then released it and let the camera reboot.3. Reconfiguration: After the reset, I had to re-add the camera to my Wyze account. This involved going through the setup process again, which was a bit tedious but ultimately worth it.4. Testing in Different Environments: I also tested the camera in different locations to rule out any environmental interference. Surprisingly, moving it to a different room didn’t resolve the issue, which confirmed it was hardware-related.5. Contacting Support: When all else failed, I reached out to Wyze support directly. They were prompt in their response and suggested a diagnostic tool to check the camera’s audio output. It turned out there was a minor hardware malfunction that couldn’t be fixed through software alone.6. Replacement: Unfortunately, the buzzing persisted even after all these steps. Wyze was great about it and offered a replacement under warranty. The new camera arrived quickly and worked without any issues.Key Takeaways:- Always check for firmware updates first.- Don’t hesitate to perform a factory reset if issues persist.- Keep your receipt and warranty information handy for potential replacements.- Reach out to support early if you’re stuck—they’re usually very helpful!I hope this guide helps anyone else experiencing similar issues with their Wyze cameras. It was a bit of a journey, but persistence paid off in the end. Happy smart home tinkering everyone! ![]()
