I recently encountered a puzzling issue with my Z-Wave switches, and I thought I’d share my journey to resolution in case it helps others facing similar challenges.
The Problem:
I set up two Z-Wave switches to mimic cross switches, like those you’d find on stairs. The idea was to control a single light from either switch. Simple enough, right? But when I tested the setup, I was met with an unexpected ‘disco’ effect—a constant flickering of the light. It was both frustrating and amusing! ![]()
The Investigation:
I quickly realized that the issue was due to the switches creating a feedback loop. Each switch was triggering the other, causing the light to toggle repeatedly. I scoured forums and documentation to understand how to break this loop without losing the functionality I wanted.
The Solution:
After some research, I discovered that the key was to configure the switches with a ‘momentary’ setting rather than the default ‘toggle’ mode. This change prevented the switches from sending continuous signals and instead allowed them to work in harmony. I also adjusted the rule in my automation software to ensure that only one switch could control the light at a time, eliminating the loop entirely.
The Outcome:
With these adjustments, the switches now function perfectly as intended. I can control the light from either switch without any unwanted behavior. It was a great learning experience, and I feel more confident tackling similar issues in the future.
Tips for Others:
- If you’re setting up cross switches, consider using momentary settings to avoid loops.
- Test your setup incrementally to catch issues early.
- Don’t hesitate to consult community forums or documentation—they’re invaluable resources!
Happy automating! ![]()
