Hi everyone, I wanted to share my recent journey in setting up an automation for my Zigbee Aqara curtains using an Aqara button. It’s been a bit of a learning curve, but I think I’ve cracked it! ![]()
Initially, my goal was straightforward: use a single press on the Aqara button to toggle the curtains open and closed. The logic seemed simple enough—check the current state of the curtains and reverse it. But as many of you might have experienced, the execution wasn’t as smooth as I hoped.
I started by setting up a basic automation in Home Assistant. The idea was to check if the curtains were open; if they were, close them, and vice versa. However, no matter how I tweaked the conditions, it just didn’t work as intended. Frustration set in, but I knew I couldn’t give up!
After some research and reaching out to the community, I realized the issue lay in how I was structuring the conditions. The “if then” option in Home Assistant was key, but I wasn’t utilizing it correctly. By redefining my conditions and ensuring the state checks were properly nested, the automation finally started working like a charm. ![]()
This experience taught me the importance of thoroughly understanding each component of an automation. It also highlighted how invaluable the community support is. If anyone else is struggling with similar setups, don’t hesitate to reach out—I’m happy to help! ![]()
Here’s a quick tip for anyone tackling similar projects: always test each part of your automation in isolation before combining them. It might save you hours of troubleshooting! ![]()
