Solving Zigbee Node Display Issues in DEVTools
Hello community, I’ve been using Zigbee devices for a while now and recently noticed something a bit puzzling. Previously, all my Zigbee nodes were neatly organized in the order they were added, making it easy to manage and identify each device. However, after a recent update, the nodes in the DEVTools are displayed in a completely random order, which has made it a bit challenging to keep track of everything.
I’ve included some screenshots below to illustrate what I’m seeing. As you can tell, the nodes are no longer listed in the sequence they were enrolled, which was a huge help for maintaining an overview. I’m curious if this is a known behavior or if there’s a setting I might have accidentally changed that’s causing this shift in display order.
If anyone has encountered a similar situation or knows of a workaround, I’d greatly appreciate the insight. It would be fantastic to get back to having a more structured view of my Zigbee devices!
Looking forward to hearing from you all.
Best regards,
