Sonos integration
I recently noticed that it’s now possible to control Sonos products locally instead of through the cloud. However, it’s no longer possible to use a card in the dashboard to control the device, the card simply disappears. Even if I try to manually add a card for the newly added local device, it’s not available in the list. When I switch back to the cloud integration, the card reappears. I’ve already contacted support, but no solution so far. Has anyone else experienced this issue?
The function is new and therefore sometimes there may be problems with device maps on the main screen, in Lan mode. I think this will be fixed in the future.
Hey, did either of you have to do anything special to get local control to work?
I stepped through the auth flow and added the devices, but they don’t seem to actually work. M3 Hub connected via Ethernet to the same router the Sonos’ are connected via WiFi.
You have to delete it and add it again. You will have the option to choose.
