Spotify Connect Device Automation Success Story
I’ve been exploring ways to integrate my Spotify Connect devices with my Home Assistant setup, and I’m thrilled to share my success story! :notes:
For those who might be interested, my goal was to automatically power on my amplifier when I switch to using my Spotify-connected Echo device. After some research, I discovered that Home Assistant has built-in Spotify integration that can detect the active output device. Here’s how I did it:
  1. Configuration: I set up a template sensor to track the active Spotify device using the source attribute. This sensor updates in real-time whenever I switch devices in Spotify.
  2. Automation: With the sensor in place, I created an automation that triggers when the sensor detects my Echo device as the active output. This automation then turns on my amplifier, ensuring smooth playback every time.
  3. Testing: It took a few tweaks, but once everything was configured, it worked like magic! Now, I don’t have to manually switch devices—I just play music, and the system handles the rest.
This setup has made my music experience so much more seamless. If anyone has similar integration ideas or questions, I’d be happy to share more details or troubleshoot together! :headphones::sparkles:
