Hi everyone, I’ve been trying to get Spotify integrated into my Home Assistant setup, but it’s been a bit of a rollercoaster. Let me share my journey and maybe we can help each other out!
First off, I installed Home Assistant on my Raspberry Pi and everything seemed to be going smoothly until I hit the Spotify integration. I followed the documentation, created a Spotify developer account, and generated my client ID and secret. But no matter what I did, I kept getting the same error: ‘Install aborted, check the documentation.’ Frustrating, right?
After some digging, I realized that the Spotify integration requires specific permissions that I hadn’t set up correctly. I had to enable the ‘Spotify for Developers’ account and ensure that my app was properly configured. Once I did that, I retried the integration, and voilà! It worked!
But the fun didn’t stop there. I noticed that some features like transferring the queue between devices weren’t working as expected. It turns out, this is a known limitation when starting playback from the Spotify app instead of Home Assistant. To get around this, I started using Home Assistant to initiate playback, which allows me to transfer the queue seamlessly. It’s not perfect, but it’s a workaround that works for now.
If anyone else is struggling with Spotify integration, here are a few tips:
- Double-check your Spotify developer account settings.
- Ensure your client ID and secret are correctly entered in Home Assistant.
- Try initiating playback directly from Home Assistant if you’re having trouble with transfers.
It’s been a bit of a challenge, but with some persistence, I’ve managed to get Spotify working in a way that fits my setup. I’m curious to hear if others have faced similar issues or have found better solutions! Let’s keep the conversation going and help each other out. Happy automating! ![]()
