Hello everyone, I’m really enjoying diving into the world of smart home automation. It’s amazing how much I can control and automate with the right setup. However, I’ve encountered a couple of issues that I’d love to get some advice on.
Firstly, since the last Core update, I’ve noticed that I can’t play Spotify content through my Music Assistant devices anymore. It’s pretty frustrating because I can browse through my Spotify library just fine, but when I try to play anything, nothing happens. It works perfectly with other sources, just not Spotify. I’m not sure if it’s a compatibility issue or if there’s a setting I need to adjust. Has anyone else experienced this?
Another issue I’m facing is with my Sonoff Zigbee temperature and humidity sensor. The readings are showing up without decimal points, which makes them a bit harder to read. For example, instead of seeing 22.5°C, it just shows 22.5C. I’m not sure if this is a formatting issue or if there’s a way to adjust the settings to include the decimal points. Also, my TH16 sensor seems to be working okay, but I’d like to make sure everything is configured correctly.
On a more positive note, I’ve been really impressed with how much I can integrate different devices and systems. I’ve managed to set up a pretty seamless system using Alexa and the Home Assistant community integrations. It’s been a bit of a learning curve, but the sense of accomplishment when everything works together is fantastic.
I’d love to hear from anyone who has successfully integrated multiple brands and devices into their smart home setup. What challenges did you face, and how did you overcome them? Any tips or tricks would be greatly appreciated!
Thanks in advance for your help and insights. I can’t wait to continue exploring and improving my smart home setup.
