Hey everyone! I wanted to share a tip that might help those of you experiencing issues with Zigbee device IDs changing every time you restart or reconfigure your Home Assistant setup. I stumbled upon this problem while integrating my Zigbee buttons and switches, and it was quite frustrating to have to reset everything each time.
After some research and experimentation, I discovered that using the deCONZ integration with Home Assistant can provide a more stable setup. By ensuring that the device IDs are correctly assigned and stored, you can avoid the hassle of reconfiguring automations after every restart.
Here’s a quick tip: If you’re renaming devices or updating your setup, try using the Entity Registry in Home Assistant. This allows you to assign custom names and entity IDs that persist even if the underlying device IDs change. It’s a lifesaver for maintaining consistent automations!
I’d love to hear if anyone else has found solutions or workarounds for this issue. Let’s keep the community knowledge flowing! ![]()
