I’ve been working on setting up a motion sensor automation for my staircase, and I thought I’d share my journey and some tips for anyone else tackling a similar project. Motion sensors and flux LED light strips are such great tools for creating a seamless lighting experience, but getting everything to work smoothly can be a bit tricky!
My setup involves two motion sensors—one at the bottom of the stairs and one at the top—and a single flux LED strip running the entire length of the stairs. The goal was to have the lights turn on when someone walks up or down the stairs and turn off when they exit the stairwell. Sounds simple enough, but getting the automation just right took some trial and error.
Here’s what I learned:
- Start Small: Begin by testing each motion sensor individually to ensure they’re detecting motion correctly. I found it helpful to use a simple “on” and “off” rule for each sensor before trying to coordinate them.
- Use a Visual Timer: I added a visual timer to the lights to confirm when they were turning on or off. This helped me debug any issues with the automation logic.
- Coordinate Sensors Carefully: Since my stairs wrap around a corner, I had to make sure the sensors weren’t triggering each other unnecessarily. Adjusting the sensitivity settings on the sensors was key.
- Test in Stages: Don’t try to set up the entire automation at once. Test the bottom sensor first, then the top sensor, and finally combine them.
- Use a Smart Hub’s Visualization Tools: My smart hub has a great rule editor with visual flowcharts. Using this made it easier to see how the sensors and lights were interacting.
- Consider Exit Delays: To prevent the lights from turning off as soon as someone stops moving, I added a short delay after motion stops. This ensures the lights stay on long enough for someone to reach the top or bottom safely.
- Log Everything: Keeping a log of when the lights turned on and off helped me identify any patterns or issues in the automation.
After a lot of tweaking, I finally got everything working perfectly! The lights now turn on smoothly when someone approaches the stairs and stay on just long enough for safe navigation. Turning them off automatically after the stairwell is empty helps save energy too.
If you’re new to automation like I am, don’t get discouraged by the learning curve. Every adjustment brings you closer to the perfect setup. Happy automating! ![]()
