Stopping Irrigation Script and Closing Valves
I’ve been working on automating my garden irrigation system using a script, and I wanted to share my experience and a solution I found. Here’s the story:
I set up my irrigation system using a script that I trigger through a dashboard switch. The script works perfectly for starting the irrigation, but I noticed an issue when I wanted to stop it early. When I ended the script via the dashboard button, the valves stayed open because their state wasn’t reset. This meant water kept flowing until I manually turned them off, which wasn’t ideal.
After some research and trial and error, I figured out a solution. I created a secondary script that runs when the dashboard button is switched off. This script ensures that all valves are closed properly, preventing any water wastage. It’s a simple yet effective fix that makes the system much more user-friendly.
Here’s how it works:
  1. When I press the stop button, the main irrigation script halts immediately.
  2. A secondary script kicks in, checking the state of all valves.
  3. If any valves are still open, they get closed automatically.
  4. A confirmation message pops up on my dashboard, letting me know everything is shut off.
This setup allows me to start and stop the irrigation system with just a tap, without worrying about leaving valves open. It’s been a great improvement, and I’m happy to share this solution with anyone facing a similar issue!
If you have questions or suggestions for improving this setup, feel free to reach out. I’d love to hear how others are handling irrigation automation in their smart homes! :seedling::droplet:
