Hello, everyone! I’m excited to share my journey and findings on how to efficiently update Home Assistant (HA) configurations using Node-RED. After experimenting with various methods, I discovered a streamlined approach that can handle multiple entities without cluttering your workflow. Let me walk you through my process and some tips I’ve picked up along the way.First, I wanted to ensure that certain entities maintain stable states even during system restarts or power failures. Initially, I found it straightforward to update a single entity’s state using Node-RED’s update config node. However, scaling this to multiple entities seemed daunting. Each entity would require its own node, leading to a messy setup. I decided to explore alternative methods to handle this more elegantly.I stumbled upon the api-render-template node, which allows me to dynamically generate state updates based on multiple entities. By crafting a template that fetches the current states of several entities, I can send a consolidated update to HA. This approach not only simplifies the workflow but also keeps the Node-RED canvas clean.Here’s a quick breakdown of how I implemented this:1. Data Extraction: I used the api-render-template node to pull the current states of the desired entities. This node is incredibly versatile and can be customized to suit your needs.2. Data Transformation: The fetched data is then processed using a function node. Here, I converted the raw data into a structured format that HA can easily interpret.3. Configuration Update: Finally, the transformed data is fed into the ha-update-config node, which updates the respective entities in HA.This setup has been a game-changer for me. It allows me to manage multiple entities seamlessly, ensuring that their states remain consistent even after system restarts. Plus, it’s much more efficient than handling each entity individually.I’d love to hear from others who might have tackled similar challenges or have suggestions for improvement. Let’s continue to explore and optimize our Node-RED setups together!Happy automating! ![]()
