I’ve been diving into the world of Zigbee devices and I must say, it’s been quite the adventure! I recently purchased a Conbee II Zigbee stick and installed Deconz through Docker, hoping to integrate my IKEA Tradfri light bulbs into my Home Assistant setup. However, I’m running into some issues that have me a bit puzzled. Let me walk you through what I’ve done so far and where I’m stuck.
First, I set up my Docker environment with the Conbee II stick connected to ttyACM1. I can access the Deconz gateway at 192.168.1.16:8080, and while Home Assistant does recognize the virtual sensor, I can’t seem to get the light bulbs to pair through the Deconz interface. I’ve tried searching for a way to pair them directly through Home Assistant, but I haven’t found a clear solution yet.
I’m using the latest version of Deconz (v.2.05.72), but the firmware status shows as “not connected,” which might be part of the problem. Could this mean that my stick isn’t functioning properly? I’ve double-checked the Docker setup and the permissions, but everything seems to be in order. I’m wondering if there’s a specific firmware version I should be using or if there’s a configuration step I’m missing.
If anyone has successfully paired IKEA Tradfri bulbs with Deconz and Home Assistant, I’d love to hear your tips or troubleshooting steps. Maybe there’s a setting I overlooked or a different approach I should try. I’m determined to get this working, but I could really use some guidance from the community!
Thanks in advance for your help! ![]()
