Success with Tamota-Flashed UK Tuya Sockets
Hello everyone! I wanted to share my recent success with integrating some UK Tuya sockets into my smart home setup using Tamota firmware. After spending quite a bit of time researching and experimenting, I managed to get everything working smoothly, and I’d love to share my experience in case it helps others facing similar challenges.
First, I’d like to thank the community for all the resources and guidance available. I stumbled upon this thread while searching for compatible UK Tuya sockets that could be flashed with Tamota. After some trial and error, I found that the Woomi Smart Plug (Model: WSP-003) works perfectly for this purpose. These plugs are widely available in the UK and have been a reliable addition to my setup.
Here’s a quick rundown of my process:
  1. Identifying the Right Plug: I started by looking for plugs that are known to be compatible with TuyaConvert and Tamota. The Woomi WSP-003 was recommended in a few forums, so I decided to give it a try.
  2. Flashing Process: Using TuyaConvert, I was able to flash the plugs with Tamota firmware without any issues. The process was straightforward, and the community documentation was incredibly helpful.
  3. Integration with Home Assistant: Once flashed, integrating the plugs into my Home Assistant setup was seamless. They showed up as Tuya devices, and I was able to configure them within minutes.
  4. Performance: I’ve been using these plugs for about a week now, and they’ve performed exceptionally well. They’re responsive, and the energy monitoring feature has been a great addition to my setup.
I’d love to hear from others who have successfully flashed UK Tuya sockets with Tamota. What models have worked well for you? Any tips or tricks you’d like to share? Let’s keep the knowledge flowing!
Cheers,
