Successful Integration of Classic Doorbell System with Modern Smart Devices
I’ve always been fascinated by the idea of blending classic hardware with modern smart tech. Recently, I took on a project to integrate my old-school Ritto 6111 doorbell system with a Nuki Opener, and I’m thrilled to share my success story with you all!
The Challenge:
My apartment building has a traditional 4-wire analogue doorbell system that’s been in place for years. While it works perfectly for its intended purpose, I wanted to bring it into the 21st century by enabling remote access and integration with my smart home ecosystem. The goal was to allow residents to unlock the building door remotely while maintaining the existing doorbell functionality.
The Solution:
After some research, I discovered that the Nuki Opener could be a perfect fit for this project. The key was figuring out how to connect the old system with the new smart device. Here’s what I did:
  1. Wiring Setup:
    • Connected the system ground (GND) from the Nuki Opener to the building’s existing ground to ensure a stable connection.
    • Wired the door opener signal (50V) directly to the Nuki’s OPEN terminal.
    • To address the noisy ring signal, I created a custom triad gong system using the RING DETECT OUTPUT and INPUT terminals. This setup not only improved the sound quality but also provided a clear distinction between doorbell rings and system notifications.
  2. Signal Management:
    • The Nuki Opener detects the ring signal from the building’s door stations. Once a ring is detected, the system is ready to receive unlock commands.
    • To prevent interference, the system resets after each use, ensuring smooth operation.
  3. User Experience Enhancements:
    • I added visual indicators in the lobby to show when the system is active and ready to receive unlock requests.
    • Residents can now unlock the door using their smartphones or through the Nuki app, while the traditional doorbell system remains fully functional.
The Outcome:
This integration has been a huge success! The building door can now be unlocked remotely, enhancing security and convenience for all residents. The traditional doorbell system still works perfectly, and the custom gong provides a pleasant and clear sound.
Tips for Others:
  • If you’re working with older systems, take the time to thoroughly understand the existing wiring and signal flows.
  • Don’t hesitate to get creative with your solutions. Sometimes, a simple hardware modification can make a world of difference.
  • Always test your setup thoroughly before finalizing it to ensure everything works as expected.
I’m incredibly proud of how this project turned out, and I’m excited to see how others might adapt similar solutions for their own smart home projects. If you have any questions or need advice, feel free to reach out—I’d be happy to help!
Happy tinkering! :hammer_and_wrench:
