Hello everyone, I wanted to share my recent success in integrating custom SVG icons into my Home Assistant setup. After some research and trial and error, I managed to get everything working smoothly!
First, I copied my SVG files to the /config/www directory. I made sure to restart Home Assistant to ensure the changes took effect. Initially, I was a bit puzzled when the icons didn’t appear as expected in the entity icon selection menu. I checked the logs and didn’t find any errors, which was a bit confusing.
After some digging, I realized that while the custom SVG method works, it’s essential to ensure that the file paths are correctly set and accessible. I also explored the entity_picture attribute as an alternative, which provided a reliable workaround. However, I was happy to discover that my initial approach with custom SVGs eventually worked once I double-checked the file permissions and ensured they were correctly formatted.
Here’s a quick tip for anyone attempting this: After placing your SVG files in the correct directory, restart Home Assistant and then refresh the entity configuration page. This ensures the system picks up the new icons without any hiccups.
I’m thrilled with how this enhancement has personalized my Home Assistant interface. It’s a small tweak that makes a big difference in the user experience. If anyone has questions or runs into similar issues, feel free to reach out—I’d be happy to help!
Best regards,
Hendrik
