After spending hours researching and comparing various smart home sensors, I finally decided to go with the Monoprice Z-Wave Plus PIR Multi Sensor. The ability to monitor temperature, humidity, and light levels all in one compact device seemed too good to pass up! Plus, the fact that it’s Z-Wave Plus certified meant it would seamlessly integrate with my existing SmartThings ecosystem. I couldn’t wait to get started.The setup process was surprisingly straightforward. Using the SmartThings app, I was able to pair the sensor within just a few minutes. The app detected it almost instantly, and I had it up and running in no time. I was thrilled to see it showing up in my device list, ready to provide real-time data on my home’s environment. The initial temperature and light readings were accurate, and the motion detection worked flawlessly—perfect for keeping an eye on things while I’m away.However, there’s always a catch, right? While the temperature and motion sensors are performing admirably, I noticed something odd: the humidity readings weren’t showing up at all. I checked the device handler and made sure all settings were correctly configured, but no luck. I started to wonder if there was a firmware update I was missing or if there was an issue with the sensor itself.After some quick research and reaching out to the community, I discovered that others have encountered similar issues. It seems that the humidity feature might require a specific device handler or some custom configuration to work properly. I’m determined to figure this out, as I really want to take full advantage of all the sensor’s capabilities.In the meantime, I’ve been using the temperature and motion data to create some cool automations. For instance, I set up a routine where the lights turn on when motion is detected and the temperature drops below a certain threshold. It’s been a lifesaver during the colder months, ensuring my home stays cozy without me having to lift a finger.I’m hopeful that with some tweaking and the help of the SmartThings community, I’ll be able to get the humidity sensor working as intended. In the meantime, I’m enjoying the benefits of having such a versatile device in my smart home setup. It’s just a matter of time before everything is running smoothly!
