Hello everyone! I wanted to share my recent experience integrating several smart home devices into my ecosystem. It’s been a journey filled with excitement and learning, and I’d love to pass on some tips that might help others.
First, I started with the Yeelights CT bulbs. They work perfectly with Home Assistant Core, but I noticed that after a restart, I had to manually power cycle each bulb. After some research, I found that checking logs and ensuring the integration was up-to-date helped resolve the issue. It’s always good to review the logs if something doesn’t work as expected!
Next, I integrated the Shelly 2.5 devices. Initially, I struggled with inaccurate power readings. Through some calibration and adjusting the config file, I managed to get more accurate readings. It’s a bit technical, but with patience, it’s doable. I’d recommend exploring linear calibration if you’re facing similar issues.
I also wanted to automate my boiler control. Using a slider to set the runtime and then turning it off after the set time was a bit tricky at first. After some trial and error with the automations, I got it working smoothly. It’s all about breaking down the problem and testing each part step by step.
One thing I’ve learned is the importance of community support. If you hit a roadblock, don’t hesitate to ask for help. Whether it’s about device compatibility, sensor calibration, or automation logic, there’s always someone willing to guide you.
Lastly, I’d like to thank everyone who contributes to forums and documentation. Your efforts make it easier for us all to create smarter homes. Keep up the great work!
Happy automating! ![]()
