Successful Integration of V-Tac WiFi Switches with Tasmota
Hello everyone, I wanted to share my recent success with integrating V-Tac VT-500x WiFi switches using Tasmota. After watching DigiBlur’s video on setting up Tasmota on new smart devices, I decided to give it a try. I’ve always been a bit hesitant with ESP8285-based devices, but this experience turned out to be quite smooth!
I purchased the VT-5005 from Amazon, and to my delight, it arrived quickly thanks to Prime. The device looked almost identical to other Chinese clones, but the real magic began once I popped off the front plate. The flashing pins were clearly visible and accessible, which made the entire process much easier.
I followed the standard procedure for flashing Tasmota onto the ESP8285 chip. The GPIO0 pin was exposed, allowing me to ground it easily and put the device into flash mode. After a few attempts, I managed to get Tasmota installed successfully. The best part was that the firmware worked perfectly right out of the box!
One thing I noticed was that the generic options in Tasmota didn’t expose all the possible pins. However, I found that selecting the right Sonoff ESP8285-based options worked like a charm. The blue backlight turned off when one or more switches were on and lit up when all switches were off, which was exactly what I wanted.
I then moved on to ESPHomeYAML, which I prefer for its direct API integration with Home Assistant. While there were a few hurdles, especially with triggers and YAML formatting, I managed to get everything working within a few hours. The end result was a fully functional, integrated system that’s been running smoothly for over 24 hours now.
This experience has been incredibly rewarding, and I’m already planning to purchase a few more of these switches for other parts of my home. If you’re looking for a reliable, cost-effective solution for your smart home setup, I highly recommend giving the V-Tac VT-500x series and Tasmota a try!
Best regards,
