I wanted to share my experience in successfully adding a delay to my Smart Home Monitor (SHM) intrusion alerts. This was a bit of a challenge, but I managed to figure it out with some trial and error. Here’s how I did it:
The Problem:
I noticed that when I unlock my front door using the keypad, the SHM system would sometimes trigger an intruder alert even though I was just entering the house. This was frustrating because it would happen even when I was in a hurry and didn’t have time to disarm the system properly.
The Solution:
After some research, I found a way to add a 20-second delay before the SHM system issues an intruder alert. This delay gives me enough time to unlock the door and disarm the system without triggering a false alarm. Here’s a breakdown of the steps I took:
Create Virtual Switches:
- I created two virtual switches in the IDE: one called “S1” and another called “S2”. These switches act as triggers for the automation process.
Configure Open/Close Sensors:
- I set up all my open/close sensors to trigger “S1” when they detect an opening. This means that whenever a door or window is opened, “S1” turns on.
Set a Timer for “S1”:
- Using the Power Allowance SmartApp, I configured “S1” to turn off automatically after 20 seconds. This creates a brief window during which I can unlock the door without triggering an alert.
Trigger “S2” When “S1” Turns Off:
- Once “S1” turns off, it triggers “S2” to turn on. This second virtual switch is essential for the next step.
Activate a Virtual Motion Sensor:
- I created a virtual motion sensor in the IDE. When “S2” turns on, it activates this virtual motion sensor, which SHM monitors for intrusion alerts.
Configure SHM to Monitor the Virtual Motion Sensor:
- I updated my SHM settings to only monitor the virtual motion sensor for intrusion alerts. This ensures that the system doesn’t react to real-time sensor data until the delay has passed.
Reset the System After a Few Minutes:
- To prevent the system from staying active indefinitely, I set up another automation to turn off “S2” and reset the virtual motion sensor after a few minutes.
The Outcome:
This setup has been working perfectly for me. The 20-second delay gives me enough time to unlock the door and disarm the system without triggering a false alarm. It’s a simple yet effective solution that has significantly reduced the number of false alerts I receive.
I hope this helps anyone else who’s struggling with similar issues. If you have any questions or need further clarification, feel free to ask!
