Successfully Adding Multiple IKEA Tradfri Gateways in Home Assistant
Adding multiple IKEA Tradfri gateways to Home Assistant can significantly enhance coverage and reliability in your smart home setup. Here’s a step-by-step guide to successfully integrating both gateways without relying on auto-discovery:
  1. Initial Setup with Auto-Discovery:
    • Start by enabling auto-discovery to ensure both gateways are recognized by Home Assistant. This quick check helps verify network connectivity.
  2. Manual Configuration:
    • Once verified, disable auto-discovery to proceed with manual setup. This approach offers precise control over your devices.
  3. Configuration Syntax:
    • Edit your configuration.yaml file to include both gateways. Use the correct syntax to specify each gateway’s IP address:
      yaml
    IKEA Tradfri
    tradfri:
    host: 192.168.1.80
    tradfri:
    host: 192.168.1.81
    • Ensure each gateway’s IP is accurately entered to avoid connection issues.
  4. Restart and Verify:
    • After updating the configuration, restart Home Assistant. Check the integrations section to confirm both gateways are successfully added.
  5. Enjoy Enhanced Coverage:
    • With both gateways integrated, enjoy improved signal strength and reliability across your home.
Tip: While manual setup provides control, consider enabling auto-discovery for future devices to simplify the process. Happy smart home managing! :rocket:
