Successfully Adjusting Aqara Motion Sensor Sensitivity
I recently faced an issue with my Aqara motion sensor RTCGQ11LM, which was overly sensitive. My little dog and even my movements closer than 10 feet would trigger it, causing unnecessary alerts. After some research and experimentation, I found a solution that significantly reduced the sensitivity without resorting to makeshift fixes like covering the lens with tape.First, I explored the settings within the Hubitat app but found no option to adjust sensitivity directly. The built-in driver didn’t offer this feature, so I had to think outside the box. I considered the sensor’s placement and realized that its position 2 feet off the ground might be contributing to the issue. I decided to experiment with different mounting heights and angles.After several trials, I discovered that mounting the sensor slightly higher and adjusting its angle to narrow the detection zone made a noticeable difference. Additionally, I found that rotating the sensor to change its field of view helped minimize false triggers from areas where sensitivity wasn’t needed.For those interested in a more technical approach, I also looked into community forums and found that some users have successfully used third-party apps or scripts to adjust sensitivity settings not available in the default driver. However, I preferred a simpler solution that didn’t require additional software.In the end, a combination of strategic placement and angle adjustment solved the problem effectively. It’s satisfying to have a sensor that now reliably detects motion without constant false alarms. This experience taught me the importance of experimenting with placement and settings when dealing with smart home devices. If anyone else is struggling with sensor sensitivity, I recommend trying these adjustments before considering more complex solutions.
