Successfully Adjusting Zigbee LED Brightness While Off - A Happy Solution!
I’m thrilled to share a successful workaround I discovered for adjusting the brightness of Zigbee LED lights without turning them on. This feature was crucial for my nighttime lighting setup, and I couldn’t find a solution for a while. Here’s how I made it happen:1. Hardware Setup: I combined MoesGo ZigBee Smart Dimmer, VARICART LED Driver, and YUNBO LED Strip Light. The key was connecting a retractive switch to the ZigBee module and wiring everything up through Z2M.2. The Surprising Fix: Initially, I thought adjusting brightness while off would either turn the lights on or have no effect. To my delight, the system registered the change, and the lights came on at the set brightness when I pressed the physical switch!3. Automation Magic: Now, I can set automations to dim the lights at night. Whether triggered by motion, a switch, or Home Assistant, the lights illuminate at the perfect brightness every time.This setup has been a game-changer for my home’s ambiance and energy efficiency. I’m excited to share this solution and hope it helps others looking for similar functionality. :star2:
