Hey everyone,
I wanted to share my recent success in setting up my Raspberry Pi 4 to boot from a USB SSD. After hearing about the limited lifespan of SD cards, I decided to explore this alternative and it’s been a game-changer!
For those interested, I followed these steps:
- Plugged in the SSD: I connected my USB SSD to one of the blue USB 3.0 ports on the Raspberry Pi 4, ensuring it gets enough power and speed.
- Used the SD Card Copier: From the Raspberry Pi desktop, I utilized the built-in SD Card Copier tool to clone everything from my SD card to the SSD. This was a straightforward process.
- Updated cmdline.txt: In a terminal, I edited the cmdline.txt file to point the root filesystem to the SSD, adding
root=/dev/sda1 rootfstype=ext4 rootwaitat the end of the first line. - Rebooted: After saving the changes, I rebooted the Raspberry Pi. It now boots from the SSD, while the SD card remains only for the initial boot process.
The results have been fantastic! The system runs much faster and I no longer worry about SD card wear. Plus, if anything goes wrong, I can easily revert by removing the SSD and booting from the SD card again.
If anyone has questions or wants to share their own experiences, feel free to drop a comment!
Cheers,
