I’m thrilled to share my recent project where I successfully built a DIY water meter sensor using a Raspberry Pi Pico W. This was a fun and rewarding challenge that I undertook to monitor my water usage more effectively. I wanted to find a solution that was both energy-efficient and easy to integrate with my existing Home Assistant setup, and I’m happy to say it exceeded my expectations!
The project started because I noticed that my water meter, which uses a metal butterfly wheel, wasn’t compatible with off-the-shelf smart sensors. I decided to create a custom solution that could detect the wheel’s rotations and send the data to Home Assistant. The key components I used were a Raspberry Pi Pico W for its low power consumption and Wi-Fi capabilities, and a simple bit counter to track the wheel’s movements.
One of the biggest challenges was ensuring the system remained energy-efficient. I designed it to only turn on the Wi-Fi for brief moments every 16 liters, which significantly reduces power usage. In its normal state, the system draws just 5mA, and peaks at 93mA when transmitting data. This setup should allow it to run for several days on a single battery charge, which is perfect for my needs.
The entire project is documented on GitHub, where I’ve shared the code and step-by-step instructions. I hope this helps others who might be facing similar challenges with their water meters. It’s been incredibly satisfying to see this project come together and start providing valuable data to monitor my water usage more closely.
I can’t recommend DIY projects enough for those looking to customize their smart home setups. It’s a fantastic way to learn new skills and create solutions tailored to your specific needs. If anyone has questions or wants to share their own DIY projects, I’d love to hear about them!
