Hey everyone, I wanted to share my recent success in setting up a smart dimmer with override functionality in my daughter’s room. This setup has been a game-changer for our bedtime routine, and I thought I’d walk through the process in case anyone else is looking to do something similar.### The ChallengeMy daughter has recently discovered the joy of turning on her overhead lights at bedtime, which has made it quite challenging to get her to sleep. To address this, I wanted a solution that would allow me to disable the physical light switch at night while still being able to control the lights remotely via my phone. Additionally, I needed the lights to remain functional during the day for her safety and comfort.### Research and SetupAfter some research, I came across the GE Z-Wave Plus Plug-In Dual Outlet Smart Dimmer. This device seemed perfect for my needs as it allows for both local and remote control. I decided to install it to replace the existing dimmer switch in her room.Here’s a quick rundown of the steps I took:1. Installation: I started by replacing the old dimmer switch with the GE Z-Wave Plus dimmer. The installation was straightforward, and I followed the instructions provided by the manufacturer.2. Pairing with SmartThings: Once installed, I paired the dimmer with my SmartThings hub. This process was seamless, and the device was recognized immediately.3. Configuration: Using the SmartThings app, I configured the dimmer to create a routine where I could disable the physical switch at night. This was done by setting up a rule that would turn off the dimmer and prevent it from being turned on manually during specific hours.### The SolutionThe key to this setup was the ability to create a routine that disables the physical switch while still allowing remote control. Here’s how it works:- Disable Physical Switch: At bedtime, I use the SmartThings app to disable the physical switch. This means my daughter can no longer turn the lights on herself.- Remote Control: If I need to check on her during the night, I can use the app to turn the lights on to a low level, providing just enough light to navigate safely without disturbing her sleep.- Re-enable During Day: In the morning, I simply re-enable the physical switch, allowing normal use throughout the day.### Tips and Tricks- Z-Wave Range: Ensure that the dimmer is within range of your Z-Wave hub. I placed mine in a central location to maximize coverage.- Firmware Updates: Keep the firmware of your devices up to date. This helps in maintaining optimal performance and security.- Testing: Before finalizing the setup, test all functionalities to ensure everything works as intended.### ConclusionThis setup has been a lifesaver for our bedtime routine. It’s been incredibly satisfying to see how technology can solve everyday challenges in such a simple yet effective way. If anyone else is looking to implement something similar, I highly recommend the GE Z-Wave Plus Plug-In Dual Outlet Smart Dimmer. It’s versatile, easy to set up, and integrates seamlessly with SmartThings.Thanks to the SmartThings community for all the helpful resources and support! Happy automating everyone! ![]()
