Successfully Configuring Bond Device for Fan Speed Control in Home Assistant
Hey everyone! I just wanted to share my experience with integrating the Bond device into my Home Assistant setup. I’ve been trying to get my fans to adjust their speed through automations, and it was a bit of a puzzle at first, but I figured it out!
Initially, I set up the Bond integration, and everything worked smoothly for turning the fans on and off. However, when I tried to create an automation to change the fan speed, the drop-down menu only showed ‘on’, ‘off’, and ‘toggle’. That was frustrating because I knew the Bond device supported speed adjustments. After some research, I discovered that I needed to use the correct service calls in my automations.
Here’s how I made it work: I used the fan.set_speed service with the appropriate speed values. For example, to set the fan to high speed, I used:
yaml
service: fan.set_speed
data:
entity_id: fan.living_room_fan
speed: high
I also created a scene to adjust multiple fans at once, which was perfect for creating a cozy evening ambiance. The key was understanding that the Bond integration requires specific service calls rather than relying solely on the UI options.
This experience taught me the importance of checking the documentation and community forums when facing integration challenges. It’s also a great reminder that sometimes a little trial and error can lead to the solution. I’m now excited to explore more advanced automations with my Bond devices!
If anyone else is struggling with similar issues, feel free to reach out. I’d be happy to share more details or troubleshoot together!
