Successfully Configuring Eglo Connect-Z Zigbee Lights for Independent CCT and RGB Control
Recently, I’ve been diving into the world of smart lighting, and I must say, the Eglo Connect-Z Zigbee lights have been a fascinating project. The idea of having both CCT and RGB controls independently seemed a bit daunting at first, but I’m thrilled to share my journey and the solution I found!
Initially, I encountered the same issue as many others—getting the CCT and RGB channels to work independently without interfering with each other. After some research, I stumbled upon a discussion suggesting the use of an external converter. However, since the Eglo lights don’t have separate endpoints, this approach didn’t seem straightforward.
I decided to explore the configuration files and templates within my Zigbee2MQTT setup. After several trials and errors, I realized that adjusting the light templates to separate the CCT and RGB channels was the key. By assigning different light controls within the template, I could ensure that each channel operated independently.
Here’s a quick breakdown of what worked for me:
  1. Identify the Channels: Recognize which channels correspond to CCT (warm and cold white) and RGB (backlight).
  2. Adjust the Templates: Modify the light templates to create separate controls for each channel. This involved specifying the exact channels for CCT and RGB in the template configuration.
  3. Test the Setup: Gradually test each control to ensure they don’t interfere. This was crucial to confirm that turning off one channel didn’t affect the other.
The result? Perfect independent control! The CCT channels handle the main lighting, while the RGB backlight adds a vibrant touch without any conflicts. It’s incredible how tweaking the configuration can unlock such functionality.
If anyone else is tackling a similar project, I’d highly recommend diving into your configuration files and experimenting with templates. It’s a bit of a learning curve, but the payoff is well worth it. Happy smart lighting!
