Successfully Configuring ESPHome for Gosund WP3 Smart Plugs
Recently, I embarked on an exciting journey to integrate ESPHome into my Gosund WP3 smart plugs, which I had previously set up with Tasmota following digiblur’s excellent instructions. The process was both challenging and rewarding, and I’d like to share my experience in case it helps someone else.
After successfully flashing Tasmota, I decided to explore ESPHome, a project I hadn’t worked with before. I installed the ESPHome add-on in Home Assistant and followed the guide to create my first node. The hidden network setup required some additional tweaks in the code, which I managed to incorporate with the help of resources I found online.
The initial step of uploading the ESPHome firmware via Tasmota’s update feature seemed straightforward. However, I encountered an unexpected issue where the device connected to my router but didn’t show up in ESPHome, despite multiple reboots of both the router and Home Assistant. This was perplexing, and I spent quite some time troubleshooting the connection settings.
After revisiting my configuration, I realized that adjusting the manual IP settings and ensuring the fallback hotspot was correctly configured played a crucial role. I also made sure that the logging and API components were properly set up to aid in debugging. Finally, after several iterations of testing and refining my code, the device came online, and everything started working as intended.
This experience taught me the importance of meticulous configuration and the value of the ESPHome community’s resources. It’s amazing how a seemingly complex issue can be resolved with persistence and the right guidance. I’m now excited to explore more advanced features of ESPHome and see how they can enhance my smart home setup.
If anyone else is attempting a similar project, I’d recommend thoroughly checking your network settings and ensuring all fallback mechanisms are in place. Happy coding and integrating!
