Hello OpenHAB enthusiasts! I wanted to share my journey in configuring MQTT with SSL on my OpenHAB 3.2.0 setup. After encountering some initial challenges, I managed to get everything working smoothly. Here’s how I did it, in case anyone else is tackling the same issue.
Understanding the Challenge
Setting up MQTT with SSL can be a bit daunting for those new to the configuration process. I had the unencrypted MQTT working without issues, but adding SSL introduced a few hurdles. I realized that understanding the SSL certificate setup was crucial for securing my MQTT broker properly.
Step-by-Step Solution
Certificate Authority Setup:
I started by creating a Certificate Authority (CA) certificate and key. This involved using OpenSSL commands to generate the necessary files. Here’s the command I used:
bash
cd /etc/mosquitto/ca_certificates/
sudo openssl req -new -x509 -days 400 -extensions v3_ca -subj ‘/C=FI/L=Some City/CN=192.168.1.140’ -keyout mosquitto-certificate-authority.key -out mosquitto-certificate-authority.crtThis created the CA files needed for the SSL setup.
TLS Configuration:
Next, I generated the server certificate and key. This required creating a Certificate Signing Request (CSR) and then signing it with the CA. The commands were:
bash
cd /etc/mosquitto/certs/
sudo openssl genrsa -out mqtt-server.key 2048
sudo openssl req -new -out mqtt-server.csr -key mqtt-server.key -subj ‘/C=FI/L=Some City/CN=192.168.1.140’
sudo openssl x509 -req -days 367 -CA …/ca_certificates/mosquitto-certificate-authority.crt -CAkey …/ca_certificates/mosquitto-certificate-authority.key -CAcreateserial -in mqtt-server.csr -out mqtt-server.crtThese commands set up the server-side SSL certificates.
Configuration File:
I then created a new encryption configuration file at/etc/mosquitto/conf.d/encryption.confand added the following lines to specify the SSL settings:
plaintext
port 8883
cafile /etc/mosquitto/ca_certificates/mosquitto-certificate-authority.crt
keyfile /etc/mosquitto/certs/mqtt-server.key
certfile /etc/mosquitto/certs/mqtt-server.crt
tls_version tlsv1.2This file tells Mosquitto to use SSL on port 8883.
Restarting Mosquitto:
After setting up the certificates and configuration, I restarted Mosquitto to apply the changes:
bash
sudo systemctl restart mosquittoIt’s important to check the status of the service to ensure there are no errors:
bash
sudo systemctl status mosquitto.service
Testing the Configuration
Once everything was set up, I tested the connection using an MQTT client that supports SSL. I made sure to use the correct port (8883) and the client certificate for authentication. The connection was successful, and I could publish and subscribe to topics securely.
Troubleshooting Tips
If you encounter issues, here are some steps to take:
- Check Logs: Look at the Mosquitto logs for error messages. This can provide clues about misconfigurations.
- Verify Permissions: Ensure that the Mosquitto user has the correct permissions to access the certificate files.
- Test Without SSL: Temporarily disable SSL to isolate whether the issue is with the SSL configuration or another part of the setup.
Conclusion
Configuring MQTT with SSL on OpenHAB was a rewarding experience. It not only enhanced the security of my setup but also deepened my understanding of SSL certificate management. If anyone else is working on this, I hope this guide helps you navigate the process smoothly. Happy automating!
If you have any questions or need further assistance, feel free to reach out. I’d be happy to help!
