Successfully Configuring Multiple NICs in Home Assistant Docker
Hey everyone, I wanted to share my experience with configuring multiple network interfaces in Home Assistant using Docker. This was a bit of a challenge, but I managed to work through it, and I hope my journey can help others who might be facing similar issues.
So, here’s the background: I’m in the process of enhancing my home LAN security by moving all my IoT devices into a non-Internet-connected VLAN. This means my Home Assistant setup, which runs in VLAN A (Internet-connected), needs to communicate with devices in VLAN B. Initially, I encountered some limitations with certain integrations, particularly with discovering devices like my air conditioning unit. I assumed this was due to Layer 2 broadcasts not being forwarded across VLANs.
To tackle this, I decided to add another NIC configured in VLAN B to my Home Assistant Docker container. My Docker Compose setup included both VLAN A and VLAN B, but I noticed that only the first network was being recognized by the container. This was frustrating because I couldn’t get the second NIC to show up within the system or network as expected.
After some research and experimentation, I stumbled upon the auto-configure option in the Home Assistant settings. It turns out that simply enabling this option did the trick! Once I unchecked the auto-configure tick, the additional NIC became available for selection. This was a relief because it meant I could now manage both VLANs effectively without compromising on security or functionality.
This experience taught me the importance of exploring all available settings, even if they seem unrelated at first glance. Sometimes, a simple toggle can resolve what initially appears to be a complex issue. I’m now able to seamlessly integrate devices across multiple VLANs, which has significantly improved my home automation setup.
If anyone else is dealing with similar challenges, I’d recommend checking out the Docker Compose configuration and exploring all the settings within Home Assistant. It’s also a good reminder to keep the software updated, as new features and improvements are regularly rolled out.
Happy automating everyone! :star2:
