Successfully Configuring SolarEdge Inverter with Modbus TCP
I’m thrilled to share my recent success in configuring my SolarEdge SE5000H inverter using Modbus TCP! :sun_with_face: After some research and tinkering, I managed to integrate it seamlessly into my Home Assistant setup. Here’s a quick rundown of my journey:
The Challenge:
Initially, I faced hurdles in accessing real-time data from my inverter. The SunSpec documentation was a bit cryptic, and I wasn’t sure where to start. However, I stumbled upon a helpful community thread that provided a solid foundation for the Modbus 2 binding setup.
The Solution:
I configured a Modbus bridge in Home Assistant, ensuring the correct IP and port settings. After some trial and error with register addresses, I was able to pull in essential metrics like AC power, voltage, and temperature. The key was adjusting the scale factors to get accurate readings!
The Outcome:
Now, I have a comprehensive overview of my solar setup directly in my dashboard. It’s incredibly satisfying to see all the data neatly organized and accessible. Plus, this integration has given me valuable insights into my energy production, helping me optimize my system further.
A Tip for Others:
If you’re looking to do something similar, start by thoroughly understanding your inverter’s register map. Don’t hesitate to reach out to the community for guidance—it’s a fantastic resource!
A huge thank you to everyone who contributed to the original thread and for the continuous support in this amazing community! :pray:
