Successfully Connecting Google Calendar to OpenHAB
Hey everyone! I just wanted to share my success story in connecting my Google Calendar to OpenHAB. I’ve been trying to get this set up for a while now, and it finally clicked! Let me walk you through how I did it and maybe some tips that could help others.
The Challenge: I wanted to integrate my Google Calendar with OpenHAB to better manage my smart home routines around my schedule. After some research, I found that the Caldavio binding was the way to go. But, as many of you might have experienced, setting it up wasn’t straightforward. I kept running into 401 Unauthorized and 404 Not Found errors. Frustrating, to say the least!
The Solution: After some digging and a lot of trial and error, I realized that the key was in how I was configuring the URL. I had been using the caldavio:openhab_tasks:url syntax as described in the wiki, but it wasn’t working. Then, I stumbled upon a suggestion to use a different URL format. I changed it to caldavio:openhab:url=https://apidata.googleusercontent.com/caldav/v2/<calendar-id>@group.calendar.google.com/events and voilà! It worked like a charm.
Tips for Others:
  • Double-Check Your Calendar ID: Make sure you’re using the correct calendar ID. You can find this by going to your Google Calendar settings and exporting the calendar. The ID will be in the URL.
  • Verify Permissions: Ensure that your Google account has the right permissions for the calendar you’re trying to access. Sometimes, sharing the calendar with yourself can help troubleshoot issues.
  • Test Incrementally: If you’re still having trouble, try connecting one calendar at a time. This helps isolate where the issue might be.
The Satisfaction: Being able to tie my smart home routines to my calendar has been a game-changer. Now, my lights dim when I’m due for a meeting, and my coffee starts brewing just in time for my morning routine. It’s these little automations that make the smart home experience truly seamless.
If anyone has questions or needs help setting this up, feel free to reach out! I’d be happy to share more details or troubleshoot together. Happy automating! :rocket:
