Successfully Connecting Xiaomi Devices Without Internet
As a homeowner who recently moved into a new house, I’ve been on a quest to set up my smart home system. One of the challenges I faced was connecting my Xiaomi devices without an internet connection. Many of us rely on the convenience of the internet for setting up smart devices, but what if you want to create a fully offline smart home ecosystem? I decided to explore this and here’s my journey!
Initially, I was under the impression that Xiaomi devices require an internet connection to fetch the token needed for initial setup. However, after some research and experimentation, I discovered that it’s indeed possible to connect Xiaomi devices locally using the Mi Home app. The key was understanding how the MiOT protocol works and ensuring all devices were on the same local network.
Here’s a quick rundown of what I did:
  1. Setup the Local Network: I made sure all my Xiaomi devices were connected to the same Wi-Fi network.
  2. Mi Home App Configuration: I used the Mi Home app to discover the devices on the local network. Surprisingly, it worked without needing an internet connection!
  3. Token Management: Instead of relying on the cloud, I managed tokens locally through the app’s settings. This required a bit of tweaking, but it was doable.
  4. Integration with Home Assistant: Once the devices were recognized locally, integrating them with Home Assistant was straightforward using the Xiaomi Miio integration card.
The satisfaction of seeing all my devices work seamlessly without the internet was immense. It’s a great feeling to have control over your smart home without relying on external services. If you’re looking to create an offline smart home setup, I highly recommend exploring local network configurations and app-based token management. It’s a bit of a learning curve, but the results are worth it!
If anyone has more tips or has successfully set up a similar system, I’d love to hear about your experiences. Let’s continue to innovate and share our knowledge to make smart homes more accessible and independent!
