I’ve been tinkering with my home automation setup for a while now, and one thing that’s always bothered me is the default labeling on my energy dashboard. Specifically, I wanted to change the “Gasverbrauch” entry to “Fernwärmebezug” and update the corresponding tile to reflect this change. After spending hours searching forums and documentation, I finally found a solution that worked for me!
The process wasn’t straightforward, but it was worth the effort. I discovered that by editing the entity configuration files, I could customize the display names without affecting the underlying data. I also learned that using the HA frontend’s customization options was a much simpler approach than I initially thought.
Here’s a quick tip for anyone looking to do something similar: navigate to your entity’s settings in the HA frontend, scroll down to the “Customize” section, and you’ll find an option to change the display name. It’s a small change, but it makes my dashboard much more intuitive!
If anyone else has questions about customizing their dashboards or needs help with similar tweaks, feel free to reach out. I’d be happy to share what I’ve learned!
Cheers,
