I’m thrilled to share my success in customizing a Philips Hue wake-up light script! After some trial and error, I managed to create a smooth sunrise simulation that gently wakes me up each morning. Here’s my journey and solution, in case anyone else is looking to achieve something similar.The Goal: I wanted my bedroom lights to gradually brighten and change color from a warm, cozy setting to a cooler, energizing tone, mimicking a natural sunrise. The challenge was to ensure both bulbs in my setup worked in perfect harmony without any glitches.The Process: 1. Research and Script Development: I started by researching existing scripts and forums for inspiration. Many scripts were close, but none perfectly suited my needs. I decided to tweak one to match my Philips Hue setup and preferences.2. Testing and Adjustments: My initial script had some issues, like one bulb cycling through colors while the other turned on fully. After some debugging, I realized the problem was with the indentation and structure of the YAML file. Fixing that was key!3. Final Script: Here’s the refined version that worked flawlessly for me. It starts with a dim, warm light and gradually transitions to a brighter, cooler tone over 20 minutes:yaml# WAKE-UP LIGHT SCRIPTsunrise: sequence: - service: switch.turn_on data: entity_id: switch.shelly_shsw_1_ba60e - service: light.turn_off data: entity_id: light.bedroom_ceiling_1, light.bedroom_ceiling_2 - service: light.turn_on data: entity_id: light.bedroom_ceiling_1, light.bedroom_ceiling_2 xy_color: [0.67, 0.39] brightness: 1 - delay: seconds: 1 - service: light.turn_on data: entity_id: light.bedroom_ceiling_1, light.bedroom_ceiling_2 xy_color: [0.65, 0.41] brightness: 85 transition: 60 - delay: seconds: 60 - service: light.turn_on data: entity_id: light.bedroom_ceiling_1, light.bedroom_ceiling_2 xy_color: [0.60, 0.40] brightness: 170 transition: 60 - delay: seconds: 60 - service: light.turn_on data: entity_id: light.bedroom_ceiling_1, light.bedroom_ceiling_2 xy_color: [0.48, 0.40] brightness: 255 transition: 60Key Takeaways: - Indentation Matters: YAML files are sensitive to formatting. A single misplaced space can cause errors.- Test in Stages: Start with shorter delays to avoid waiting too long during testing.- Documentation is Your Friend: Keep notes on each adjustment to track what works and what doesn’t.A Big Thank-You to the Community: This wouldn’t have been possible without the helpful scripts and advice shared by others in forums like this. It’s amazing how a supportive community can turn a challenging project into a rewarding success!If anyone else is working on a similar project, feel free to reach out! I’d be happy to help troubleshoot or share more tips.
