Hello everyone, I wanted to share my recent experience with debugging a custom integration in Home Assistant. I’ve been trying to set up a remote Python debugger using VS Code, and while the process had its challenges, I managed to get it working smoothly. Here’s my journey and some tips for anyone else tackling this:
The Challenge
I started by following the official Home Assistant guide for remote debugging. I was able to connect to my HA instance via SSH from my Mac terminal, but VS Code threw an error: [12:15:08.839] stderr> ps: unrecognized option: p. This was frustrating because the connection worked in the terminal, but not in VS Code.
The Solution
After some research, I realized the issue was related to the ps command in the Alpine Linux environment used by Home Assistant. The ps command in Alpine doesn’t support the -p option, which caused the error. To fix this, I adjusted my SSH configuration in VS Code to use a different shell command that works seamlessly with Alpine.
Key Takeaways
- Check Your Shell Commands: Ensure the commands you’re using are compatible with the OS running on your HA instance.
- Update VS Code Extensions: Make sure your Remote-SSH extension is up to date, as newer versions often include bug fixes.
- Use the Right Configuration: Tailor your SSH config to match your environment. For Alpine, using
/bin/shinstead of/bin/zshresolved the issue for me.
The Reward
Once everything was set up, debugging became a breeze. I could step through my custom integration code, identify issues, and test fixes in real-time. It’s incredibly satisfying to see everything work as intended after overcoming those hurdles.
I hope this helps anyone else struggling with remote debugging in Home Assistant. Happy coding! ![]()
