Hey everyone, I wanted to share a fantastic experience I had recently using my Wyze Cam v3 to diagnose a persistent issue with my furnace. It was both frustrating and enlightening, and I hope sharing this can help others who might be facing similar challenges!
The Problem
Since mid-fall, my furnace had been acting up. It would randomly stop the flow of gas, then restart, only providing heat for a few minutes at a time. I couldn’t catch it throwing an error code, which made troubleshooting incredibly difficult. Traditional methods just weren’t cutting it, so I decided to think outside the box.
The Solution
I attached my Wyze Cam v3 to the front of the furnace using its magnetic base. The idea was to peek through the louvers and monitor the LED lights for any signs of trouble. I set it to record continuously and checked the footage periodically for any events. After some time, I finally caught the furnace flashing an error code—2 flashes! Unfortunately, it wasn’t consistent, but it was enough to guide me in the right direction.
The Outcome
With this information, I was able to perform some initial diagnostics before bringing in an HVAC technician. The issue turned out to be related to the inducer motor, which had been acting up. Once the motor was replaced, everything started working smoothly again!
What I Learned
- Wyze Cam’s Durability: The Wyze Cam v3 proved to be incredibly reliable, even in less-than-ideal conditions. Its ability to record continuously and provide clear footage was a lifesaver.
- Remote Monitoring Potential: This experience highlighted how valuable it is to have cameras that can monitor hard-to-reach areas. It’s a game-changer for troubleshooting and maintenance.
- Community Support: Without the insights and recommendations from this community, I might not have thought to use a camera for this purpose. It’s amazing how a little creativity and the right tools can solve even the most stubborn problems.
If you’re facing similar issues, I highly recommend considering a Wyze Cam or similar device for remote monitoring. It’s a cost-effective and innovative solution that can save you time and stress. Plus, it’s a great way to leverage your smart home setup for practical, everyday use!
A huge thank you to everyone in the community for the inspiration and support. Keep innovating and sharing your experiences—it truly makes a difference!
Best regards,
