Successfully Discovering Zigbee Devices on Multiple HA Instances with One Coordinator
Hey everyone, I wanted to share my journey of setting up Zigbee devices across two Home Assistant (HA) instances using just one coordinator. This was a bit of a puzzle, but I think I figured it out, and I hope this helps others who might be facing similar challenges!
Background
I started with a simple setup: three Zigbee devices (a motion sensor, illuminance sensor, and lightbulb), a Conbee II stick as the coordinator, and HA running on a Raspberry Pi. Everything worked smoothly with the ZHA integration, but then I migrated to Zigbee2MQTT to dive deeper into the network. This allowed me to understand the flow better: zigbee devices communicate with the coordinator, which then sends data through Zigbee2MQTT to an MQTT broker, and finally to HA.
Objective
I wanted to test my automations on a development HA instance running in a virtual machine on the same LAN without buying another coordinator. This was tricky because I wasn’t sure how to connect the USB coordinator to the virtual machine. Plus, I didn’t want to deal with port conflicts or other MQTT broker issues.
First Attempt - Not So Great
My initial idea was to bridge the two MQTT brokers (B1 and B2) so messages from my devices would be sent to B2 from B1. I followed some excellent tutorials and managed to get the bridge connected, but nothing showed up in the target MQTT client on the dev HA. After a lot of debugging, I realized the issue might be with the broker names and ports. I tried changing them, but it didn’t solve the problem, so I decided to try a different approach.
Second Attempt - Success!
Instead of bridging, I connected the development MQTT client (C2) directly to the production broker (B1). This meant I didn’t need a separate development broker. I reconfigured the MQTT integration on the dev HA with B1’s IP address, username, and password. After a few restarts and some tweaking, it worked! The dev HA discovered all the zigbee devices published by Zigbee2MQTT.
Here’s the flow that worked:
  • Zigbee devices send data to the coordinator.
  • The coordinator passes the data to Zigbee2MQTT.
  • Zigbee2MQTT sends the data to the MQTT broker (B1).
  • The production HA (HA1) and development HA (HA2) both connect to B1 and receive the data.
Key Takeaways
  1. Directly connecting the development client to the production broker was simpler than bridging.
  2. Using the IP address instead of the broker name worked better in my setup.
  3. Restarting services and checking logs were crucial for troubleshooting.
If anyone has questions or tips, I’d love to hear them! This was a great learning experience, and I’m excited to continue exploring HA and Zigbee integration.
