I’ve been diving into the world of Zigbee lately, and I must say, it’s been quite an adventure! As a newbie, I wanted to extend the range of my Zigbee sensor, which was only working within a 3-meter radius—definitely not enough for my needs. After watching several Smart Home expert videos, I figured out that adding a Zigbee repeater might be the solution. I decided to go with the SMLight SLZB-06, which I read is a reliable option for boosting Zigbee range.
The setup wasn’t too bad. I added the SLZB-06 to my Zigbee network, and it quickly found the sensor I was trying to extend. The sensor now shows up as a connected device on the SLZB-06, which is a great sign. But here’s where things got a bit tricky. Every time I tried to start Zigbee2MQTT, I kept getting a socket error in the logs. The error message was pointing to a connection reset issue, which I couldn’t quite figure out at first.
After some research and a bit of trial and error, I realized that my Mosquitto broker might not be running on the correct port or IP address. I double-checked my configuration and made sure everything was pointing to the right place. Once I fixed that, Zigbee2MQTT started without any issues, and the sensor is now working perfectly at 20 meters from my front door!
This experience taught me the importance of verifying every connection and configuration detail, even if it seems minor. It also highlighted how helpful the Zigbee2MQTT community and documentation can be when troubleshooting. If anyone else is struggling with range issues or connection errors, I’d recommend checking your broker settings and ensuring all devices are correctly paired.
Overall, I’m really happy with how this project turned out. It’s given me the confidence to tackle more complex Zigbee setups in the future. If you’re considering using a repeater like the SLZB-06, I’d say go for it—it’s a solid choice for extending your Zigbee network!
