Successfully Fixed Hue Lights Automation Issue - Tips Inside!
Hello everyone,
I wanted to share my recent experience with Philips Hue lights automation, which was a bit of a puzzle but turned out to be a great learning opportunity. I recently upgraded my Hue white bulbs to the Hue white and ambiance version, and I noticed an issue with my automations. Specifically, when I used a Hue dimmer switch to toggle lights, they wouldn’t stay at the set brightness but reverted to their previous state. This was quite frustrating, especially since it was working fine before the upgrade.
After some research and trial and error, I discovered that the issue was related to how the Hue integration interacts with the dimmer switch. Initially, I thought it might be a problem with the new bulbs, but it turned out to be a configuration settings issue. By adjusting the automation settings in Home Assistant and ensuring that the dimmer switch wasn’t conflicting with the Hue app settings, I was able to resolve the problem.
Here’s a quick tip for anyone facing similar issues:
  • Double-check your automation triggers and actions in Home Assistant.
  • Ensure that your dimmer switch isn’t configured in both the Hue app and Home Assistant, as this can cause conflicts.
  • Test each automation separately to identify where the issue might be occurring.
It’s been a while since I’ve had everything working smoothly, and I’m really happy with how the Hue white and ambiance bulbs perform now. They add a nice touch to my home theater setup!
If anyone else has questions or needs help with their Hue integrations, feel free to reach out. I’d be happy to share more details or troubleshoot together.
Best regards,
