Successfully Fixed Light Timer Issue - Share My Experience
Recently, I encountered an issue while setting up a light timer, but through careful troubleshooting and some adjustments, I managed to find a solution. I’d like to share my experience in the hope it might help others facing similar problems.
Initially, I aimed to control my lights using a Hue motion sensor. The goal was for the lights to turn on when motion was detected and then automatically turn off after 5 minutes. However, I noticed that if the motion sensor detected movement again within those 5 minutes, the timer didn’t reset, causing the lights to turn off after the initial 5 minutes regardless of continued activity.
After some research, I realized the issue likely stemmed from how the timer was configured. I revisited the rules and bindings, discovering that the timer wasn’t correctly linked to the state changes of the motion sensor. By adjusting the rules, I ensured that each time the motion sensor detected movement, the timer would reset.
This adjustment successfully made the timer reset upon detecting motion, achieving the desired functionality. Now, whenever someone enters the room, the lights automatically turn on and remain lit for 5 minutes. If movement is detected again within those 5 minutes, the lights stay on until the next period of inactivity.
This process taught me a lot about understanding how rules and bindings work together, boosting my confidence in troubleshooting future issues. I hope my experience proves helpful to others!
Best regards,
