Successfully Fixed Nest Cam Post-Power Outage Connectivity
Hey everyone, I wanted to share my experience with the Nest Cam connectivity issues after a power outage. I came across a helpful tip that really made a difference, and I thought it might be useful for others facing the same problem.
So, the issue I was having was that after a power outage, only one out of my three Nest Cams would reliably reconnect to my Wi-Fi network. It was like a lottery every time—would it be the kitchen cam, the front door, or the backyard? It was frustrating, especially since I rely on these cameras for home security.
After some research, I stumbled upon a suggestion that you can only have two cameras on a single Wi-Fi network to ensure reliable reconnection after an outage. I had three cameras, so I decided to try this solution. I had an extra router lying around, so I set up one camera on a different Wi-Fi network using that router. I tested it out, and it worked! All three cameras now reliably come online after a power outage. It’s not the most ideal solution, but it’s effective.
I know this might not be the perfect fix for everyone, but it’s worth considering if you’re experiencing similar issues. It’s all about finding a workaround that works for your setup. I’m really glad I gave this a try—it’s made a huge difference in my peace of mind.
If anyone else has tips or solutions for improving camera connectivity post-outage, I’d love to hear them! Let’s keep sharing and learning together. :rocket:
