Successfully Grouping Smart Lights with a Workaround
I recently faced the same frustration as many of you regarding the lack of built-in functionality for grouping lights into virtual switches or dimmers in the SmartThings app. After the shutdown of Trend Setter, which I relied on for this purpose, I was determined to find a solution.
After some research, I discovered that while SmartThings doesn’t natively support this feature, there are alternative methods to achieve the desired result. One effective workaround is using third-party apps like Tasker or IFTTT. These apps allow you to create custom routines that can control multiple devices simultaneously.
Here’s a simple step-by-step guide to setting this up using IFTTT:
  1. Create a New Applet: Start by opening IFTTT and creating a new applet.
  2. Choose a Trigger: Select a trigger that suits your needs, such as a location-based trigger (e.g., when you leave home) or a time-based trigger (e.g., at sunset).
  3. Add an Action: Connect your trigger to an action that controls your lights. You can set multiple actions to turn on or off different groups of lights.
  4. Test Your Setup: Once your applet is created, test it to ensure it works as expected.
This method not only allows you to group lights but also gives you the flexibility to create complex routines that suit your lifestyle. I’ve been using this setup for a few weeks now, and it’s been a game-changer for me.
If you’re looking for even more customization, Tasker offers advanced automation features that can handle more complex scenarios. It does have a steeper learning curve, but there are plenty of tutorials available online to help you get started.
I hope this workaround helps others who are seeking a similar solution. It’s amazing how a little creativity can overcome the limitations of our smart home ecosystems. Happy automating! :star2:
