Successfully Installing 2GIG Sensors with 3M Command Strips
As a renter, I’ve always been cautious about making permanent changes to my home. When I decided to install some 2GIG sensors for better home security, I knew I couldn’t drill into the walls or doors. That’s when I stumbled upon the idea of using 3M Command Strips—a genius solution that’s both temporary and effective!
My Initial Concerns:
I was skeptical at first. Would the strips hold up? Would they leave residue? But after some research, I found that 3M Command Strips are designed to be strong yet removable without damaging surfaces. Perfect for my situation!
The Installation Process:
I started with the 2GIG Thin Window/Door Contact Sensors. The strips were surprisingly easy to apply. I just cleaned the surface, placed the strip, and pressed firmly. The sensors stayed put, even after a few weeks of use. Next, I tried the 2GIG PIR1 Motion Sensor. It was a bit bulkier, but the Command Strips still managed to hold it securely.
Unexpected Benefits:
What surprised me most was how well the sensors performed. They detected movements accurately and sent notifications without any lag. Plus, the strips didn’t leave any sticky residue when I decided to move them for better placement.
Tips for Others:
  • Clean Surfaces: Make sure the area is clean and dry before applying the strips.
  • Test Placement: Stick the strips temporarily to find the best position before securing them.
  • Check Compatibility: While most surfaces work, avoid textured or porous materials for better adhesion.
Final Thoughts:
Using 3M Command Strips was a game-changer for me. It allowed me to enhance my home security without any permanent modifications. If you’re in a similar situation, I highly recommend giving this method a try. It’s affordable, easy, and incredibly effective!
If anyone has questions or needs advice on installing sensors, feel free to reach out. I’d be happy to help!
