Successfully Installing Home Assistant with PyYAML 6.0
Hey everyone, I wanted to share my experience with installing Home Assistant using pip. I ran into a bit of a snag with the installation process, but I managed to figure it out!
Initially, I tried installing Home Assistant using the standard pip command, but I kept running into an AttributeError related to cython_sources and pyyaml. After some research, I found out that the issue was with the version of pyyaml I was using.
I tried installing pyyaml 5.4.1 as suggested in some forums, but that didn’t solve the problem. However, I stumbled upon a solution that recommended using pyyaml 6.0 specifically. I followed the instructions to install cython first and then pyyaml with the --no-build-isolation flag.
Here’s what worked for me:
bash
pip install “cython<3.0.0” && pip install --no-build-isolation pyyaml==6.0
After running these commands, the installation went smoothly, and I was able to get Home Assistant up and running without any further issues. I hope this helps anyone else who might be encountering the same problem!
It’s always a bit frustrating when you run into unexpected errors, but it’s satisfying to find the solution and get everything working again. If anyone else has tips or tricks for installing Home Assistant, I’d love to hear them! Happy coding! :rocket:
