After spending hours trying to figure out how to install the KNX binding on my Raspberry Pi 2, I finally managed to get it working! I wanted to share my experience in case anyone else is struggling with the same issue. Here’s what I did:
Understanding the Problem: I installed OpenHAB 2 using the openHABian package, but the KNX binding wasn’t showing up in the add-ons section. I tried downloading the JAR file and placing it in various folders, but nothing worked.
Researching Solutions: I came across several forums and guides, but most were for older versions of OpenHAB. I realized that the KNX binding might not be included by default in the newer versions, so I needed to find the right way to install it.
Finding the Right JAR File: I downloaded the latest KNX binding JAR file from the official OpenHAB repository. I made sure to get the correct version compatible with my OpenHAB setup.
Installing the Binding: Instead of manually copying the JAR file, I used the Paper UI to install the binding. Here’s how:
- Go to the Paper UI dashboard.
- Navigate to the ‘Add-ons’ section.
- Click on ‘Browse Add-ons’.
- Search for ‘KNX’ in the marketplace.
- Install the KNX binding from there.
Configuring the Binding: After installation, I configured the KNX binding using the provided XML configuration files. I made sure to set the correct IP address of my KNX gateway.
Testing the Setup: I rebooted my Raspberry Pi and checked the logs to ensure the KNX binding was starting correctly. Everything worked like a charm!
I hope this helps someone else who’s stuck with the same issue. It was a bit frustrating at first, but persistence paid off! ![]()
