I’ve been on a journey to fully integrate my smart home devices into Home Assistant, and I’m thrilled to share my success with the Wired Smart Thermostat X. After some research and troubleshooting, I managed to connect it seamlessly without needing any mains power—a huge relief since my current setup only supports low-voltage signals!
Here’s what I did:
- Checked Compatibility: I verified that the thermostat doesn’t require mains power, which was a key concern. It runs on battery and communicates via low-voltage signals, perfect for my setup.
- Configuration in Home Assistant: I used the Zigbee2MQTT integration to pair the thermostat. The process was straightforward—just a matter of resetting the thermostat and letting HA handle the rest.
- Automation Setup: I created a simple automation to adjust the temperature based on my schedule. For example, it lowers the heat when I’m away and warms up the house before I return. This has been a game-changer for energy efficiency!
Tips for Others:
- Ensure your thermostat supports Zigbee or another protocol that HA natively supports.
- Take your time during the pairing process to avoid any connection issues.
- Explore HA’s extensive automation options to maximize your thermostat’s potential.
This integration has made my home smarter and more comfortable. If anyone has questions or needs help with similar setups, feel free to reach out! ![]()
