Successfully Integrated Shelly Plug S with MQTT - Tips Inside!
I’ve been diving into the world of home automation lately, and I must say, it’s been an exciting journey! One of the devices I’ve been working with is the Shelly Plug S, and while it’s a fantastic piece of hardware, getting it to work seamlessly with MQTT was a bit of a puzzle at first. But after some research and trial and error, I’ve got it sorted out, and I’d love to share my experience with you all!
The Challenge
When I first set up my Shelly Plug S, I wanted to control it using MQTT for a more integrated smart home experience. I followed the basic setup guide, connected it to my Wi-Fi, and enabled MQTT in the settings. But here’s the kicker—nothing seemed to work! I tried sending commands through my MQTT broker, but the plug just wouldn’t respond. It was frustrating, to say the least.
The Solution
After some digging through forums and documentation, I realized the issue was with the MQTT topic structure. The default settings on the Shelly Plug S weren’t quite aligned with how my MQTT broker was expecting the commands. Here’s what I did to fix it:
  1. Double-Check the MQTT Settings
    • Ensure that MQTT is enabled on your Shelly Plug S.
    • Make sure the broker address, port, and credentials (if needed) are correctly configured.
  2. Understand the Topic Structure
    • The Shelly Plug S uses a specific topic format for commands. For example, to toggle the plug, you need to publish to shellies/<device_id>/relay/0/command with the payload on or off.
    • I found that using the Detached Switch Mode in the settings was crucial for proper MQTT integration. This mode ensures that the plug doesn’t interfere with the MQTT commands.
  3. Test with a Simple Command
    • Before diving into complex automations, test the basics. Use a tool like mosquitto_pub to send a simple command:
      bash
      mosquitto_pub -h <your_broker_ip> -t shellies/<device_id>/relay/0/command -m on
    • If the plug turns on, you’re good to go!
The Outcome
Once I got the MQTT integration working, the possibilities were endless! I set up a simple automation where my Shelly Plug S turns on my coffee maker every morning at 7 AM. It’s these small conveniences that really make you appreciate the power of home automation.
If you’re struggling with MQTT integration for your Shelly devices, don’t get discouraged! Take it step by step, double-check your settings, and don’t hesitate to reach out to the community for help. Remember, we’re all here to learn and grow together!
Happy automating, everyone! :rocket:
